# Animation settings question when using Primary BF and Secondary LC
**URL:** <https://forums.chaos.com/t/animation-settings-question-when-using-primary-bf-and-secondary-lc/49579>\
**Category:** Issues\
**Created:** [April 25, 2014, 7:48am UTC](https://forums.chaos.com/t/animation-settings-question-when-using-primary-bf-and-secondary-lc/49579 "2014-04-25T07:48:33Z")\
**Posts on this page:** 1\
**Showing post:** 6
<div class="post-metadata">
**Author:** ![tricky](https://dub1.discourse-cdn.com/chaosprd/user_avatar/forums.chaos.com/tricky/32/56653_2.png) [@tricky](https://forums.chaos.com/u/tricky)\
**Post date:** [April 29, 2014, 7:39am UTC](https://forums.chaos.com/t/animation-settings-question-when-using-primary-bf-and-secondary-lc/49579/6 "2014-04-29T07:39:29Z")
</div>
> [@Rhino crashes on opening vray scene](https://forums.chaos.com/t/rhino-crashes-on-opening-vray-scene/44612/3):
> Before to doing this please try to turn ON “Use Camera path” option for the Light cache calculations. It should reduce the flickering in your case.
Should I therefore ‘precalc’ my lightcache for the entire sequence in ‘flythrough’ mode with ‘Use Camera Path’ enabled? (I do have animated curtains in front of the window which will subtly affect the GI from frame to frame). Then for rendering the frames, I set BF as my primary engine and LC for secondary (using the saved LC solution)?
_[View the full topic](https://forums.chaos.com/t/animation-settings-question-when-using-primary-bf-and-secondary-lc/49579)._
