animation setup
If anyone could clear this up it would be much appreciated.
we always set up our animations with the settings 720 x 576 with Image aspect on 1.778 and pixel aspect ratio of 1.422. Once the images are rendered we use Premiere to “stretch” them back to widescreen 1024 x 576. But recently we’ve just bought adobe premiere CS4 to compile an animation, whats really puzzled us is the pixel aspect ratio has changed from 1.422 to 1.4587 so now when we "stretch them back they aren’t big enough and leave a black band left and right. Is there something we’ve been doing thats wrong? as the way I understood it the 1.422 aspect comes from 720 x 1.422 = 1024, with this new pixel aspect ratio it makes it 1050 wide??
Ok with CS4 there has been a change to the PAL widescreen aspect ratios.
The real pixel aspect ratio for widescreen PAL is in fact 1.4587 instead of 1.4222 and for some reason Adobe figured that CS4 was a good time to change.
if you want to know why
http://www.lynda.com/home/Player.aspx?lpk4=40550
this tells all
Thats great, thanks v much for your help, much appreciated. From now on we’ll set everything up with pixel aspect of 1.4587.
Cheers.
