Animation Test
Some school work.
It took an average of 30 sec per frame to render on my i72600K
I was getting too much flickering so I saved the HDcahe solution then rendered the video.
The video was edited in AE to remove noise and add the glow effect.
Sorry, fixed.
Not bad as for 30s per frame.
This is incredibly awesome.
Could you give a step by step as to how it was done? I’m pretty new here so more in depth the better.
Maybe screen cap of settings?
Good result, i see no flickering, maybe because it’s far
Any tips on removing noise in AE would be greatly appreciated :smiley:
Umm… how about “reduce noise” effect? :smiley:
guess it’s a bit of unsharp mask after that I was looking at more :smiley: liking it anyhow
I used path tracing for first solver and HDcache for second.
Camera Motion blur is on.
The trick (is it ?) here was to turn on “save sec.GI”, wait for HDcache calculation to end then cancel the render, turn off “save sec.Gi” and turn on “Load sec. GI” then render the whole animation.
For the noise I used Neat Video for After effects.
Nice one Sam, its good to see Corona in Animation.
cheers
Thanks Sam. That Neat Video plug-in is really cool. I’ve been looking for something like that.
hi all, this is my first animation test render, iray scene converted in 1 min, 720p 25 fps, 1.10 min per frame,
path tracing + hd cache saved in first frame, i loaded for entire animation. thats it.
some ps.
machine 2600k 4000ghz 16gb.
installed Corona today
+/- 30 sec per frame :wink:
Hello Sam75
The glow effect in this animation, I can not see it with AE
Could you be more clear with this trick?
I did not understand this step
Raf
It looks to me that same as in vray " do not render final image " if I understand correct you only need to wait for secondary GI calculation and hit Cancel render. Then use "Load from file " pointing to saved file. Am I correct?
