I’m having trouble with an animation, it’s not specific surfaces that are flickering, its the whole shot, one shot slightly darker than the next, at random intervals. I assume it’s something within the scene doing it, as other scenes render fine. I’ve tried hiding obvious offenders such as glass panels, plants, vrayfur, Phoenix etc. but it still persists. I’m using the standard settings (set renderer to scanline then back to V-ray), noise is 0.03, and the lightcache is set to 4000 with the retrace currently at 10 (I was trying higher settings to sort it out) What would cause overall scne flicker?
Hi, are you rendering on a single machine or on multiple? Could you send us a few frames so we can observe the issue? You can attach files here or open a ticket trough our support page
