animations
hi there.
i´m testing a little animation, is a ball moving by the screen. (i have the animation but don,t knos how to upgrade it to the forum..), the fact is that i´m tring with incremental add to current map, and don´t calculate the shadows in the right way, the only way to calculate it rigth is activeting single frame, but it´s slower.
what could i do?, how could i upgrade the animation to the forum? ( i have any internet place)[/url]
well. simply answered. Incremental add to current map wont work if the ball moves. Its only for camera moves. Basically an irradiance map is the map of the lighting solution of your scene. change the scene…for instance the possition of a ball, and your solution changes. therefore if you add to that current map, what your adding is not the same as what you had before so id assume your anim turned out with shadows as yummy as 4 day old oatmeal
A place for you to upload to:
Domain: ftp.3dmaxedout.com
Username: vray@3dmaxedout.com
Pasword: govray
Resulting URL: http://vray.3dmaxedout.com
thanks to both.
:wink:
