Applying cryptomatte to multi/sub material on one object and performing color correction causes anti-aliasing issues.
In versions prior to 5.1, it is not a problem because multi/sub material was not supported.
Anti-aliasing problems arise from supporting multi/sub material.
Any solution? When using vrayproxy, it is inevitable to use multi/sub material for one object.
In large-scale scenes, it is not possible to de-detach each object individually.
- Color correction was done by vrayfremebuffter (VFB).
