Good evening …
Is there a way to make the bright objects edges less sharp ?
I tried to manipulate the filtering controls but I still have a problem near bright areas.
I uploaded an image :
the light coming through the window on the floor has bright edges.
Thanks for any help.
Try increase highlight compression and Internal Res.
maru
3
Thanks.
although I was trying to avoid setting internal resolution to 2 because it increases render times.
increasing the highlight compression was useful too although it changed the total brightness of the scene.
Not 100% sure, but i think that raising internal resolution doesn’t add much to render time if at all, but it may consume more RAM.
maru
6
btw, writing just in case - you can also change sun size to make the light more blurry
