I´m new to VRAY and after lots of testing I have not got a good result with rendering. The problem is the lack of antialiasing.
I have relatively simple scene (no GI). I have set the Adaptive DMC on and tested with different adjustments but the antialiasing seems to not improve at all.
Here is some samples of my scene in 200% magnification :
It looks like there is no anti-aliasing at all.
Here are my specs :
Adaptive DMC
AA Filter : Area 2.0
Min subdivs 1 Clr treshold 0,005
Max subdivs 8
Adaptive Amount 0,85 Min samples 8
Noise treshold 0,01 Global subdivs multiplier 20,0
My guess there’s something weird with your lights. Looks like the noise is stronger closer to the lights. Check their subdivs… Looking at that ridge at the top of the picture, the AA looks fine.
Are you using sub pixel mapping?
You can also send your scene to vray@chaosgroup.com
Have you changed Global Subdivision Multiplier? for me it look like it is set to value below 1 - probably 0.5 or lower.
