this is the second times, in two different files.
Look at the rendering and the AA problem. The solution?
Just change from Corona (A) to Scanline(B) and come back to Corona(C).
If I apply the same setting from (A) to (C), no AA problem.
for me too
can you reproduce it, or is it completely random?
Random
Now I switch from Corona->Scanline->corona and I have overwritten the old file (stupid). If I will the same problem, I’ll send you the file.
Can you post this scene?
But, now, it’s ok
. All parameters are with default values. I changed just parameters in post-production rollout, PTS and LSM. That’ all.
I think the issue is with max. This happened to me countless times with vray. The only solution that I had found was, as Legrenzi said, to switch back to scanline and then back to vray. If the same problem happens with corona then I’m more inclined to think it’s max’s fault and not the renderer’s.
are you using Corona wx or 3dsmax native framebuffer?
I use only Corona VFB
hm, 3dsmax should not be able to influence it any way then. But I don’t know, it is fucking black magic ;).
I know… I’ll pay attention in the future and I’ll save the “magic” scene for your debug =)
