Hi everyone, would you have any clue to do this kind of materials?
http://www.vitra.com/products/home/living\_room\_screens/algue/default.asp?lang=il\_fr
thanks
thanks
which material?
Should I assume the tree?
yep which mtl??? :roll:
maybe they meant all the materials… notice there is an S in here post.
Nothing there looks all that difficult to be honest. But some clarification as to what you want would be great.
sorry i mean…
sorry i mean the wall in mesh. It,s call algues… the main problem is that we would see it from the side. so the opacity map wont work… Any clue.?
click on
click on ‘’ Photos ‘’ to see the kind of product. It will be more easy to see the kind of material. It’s a plastic mesh… with depth…
If you already have the opacity map texture, then I’ll say go with vray displacement.
Hint : adjust the water level setting in vraydisplacement.
Other than that, you can always just model it in max (maybe renderable spline?). Same trouble if you start from scratch.
edit: some illustration for the displacement setting:
Cheers!
Hi jodestroy,
I had to use this material for a project last year, I think I used opacity mapping on a thin box then added a noise modifier for a bit of variation.
I used this map anyway…
Hope it helps,
Dan
i agree the displacement method is going to be your best bet to getting this done
thanks guys.
thanks guys, nice work. As soon as i got something that could be usefull, i’ll post it. Will be back at work in 10 days.
thanks again for the map.
best way
finally, the best way to do it is … Spline ( line ) with radius. Enable in viewport and renderer . Like that no displacement to use ( i think it’s too time consuming with pc ) i can reduce it or not if the client ask.
thnaks for the help
I would not use displacement for something this easy to model. By taking a bit of time and modeling the shape out in splines quickly you’ll easily save the time in rendering x 10 instead of displacing it.
