I would like to model a chain like the one in the photo. If possible in a way which will allow me flexibility in adjusting the shape in which the chain ly if needed.
Spline + Loft…
in the Loft params. You will be able tu use the build in mapping system, to map this thing in no time.
In the material, I would use a Gradient Ramp in the bump slot,( using the solid preset…)
Should be done in no time
