I’d appreciate any comments from users about the compatibility of SketchUp 22 and Enscape 3.3? I teach both programs at Bellevue College and want to make sure that there haven’t been any major issues before we upgrade all the school computers. Since I’m not seeing any comments in the forum
Since no one has chimed in so far, I can also say that there shouldn’t be any major issues present at all in 3.3 that could hinder working with SU 2022 and Enscape.
If you have the chance though, simply acquire and install our latest (Service Pack) release 3.3.1 here, and try it on one of the machines first if they all have the same hardware especially. Then open one of the projects your students are usually using for example, and if you do not run into any problems you’re good to go.
It also can’t hurt to make sure that the GPU drivers on those machines are up to date about every 2-4 months ideally. Please make sure to also acquire them through either the AMD or NVIDIA driver page directly.
I’ve tested it in several situations including batch rendering, exe standalone, web standalone, several IES lighting files, different sound sources on the same scenario, shared galleries and tours with clients and so on… until now everything is SUPER DUPER OK
I am using sketchup 2022 on mac and isntalled enscape beta for mac. But i am not able to see the plugin in sketchup 2022 for mac. Is it yet not compaitable till now?
That stuff is good but heavy… Assets & Material Library, Material Editor and so on. Once I use it on Windows I don’t know if it is ON for MAC right now. For the Windows crowd is rolling just fine
If you haven’t already, please definitley send us a feedback report then. This does not seem to be a known current issue, so a report with your logs will be very helpful for us in order to troubleshoot the cause behind this.
Also, does this persist in every project of yours, or maybe just a select scene? Are your graphics card drivers fully up to date?
Hi Demian/ I just have sent feedback. My drivers is up to date fully, model is not so big (35Mb). If I open model larger freez is longer(((( If I close enscape freez is gone.
