any script like a paint tool for trees ?
I am sur this was asked several times.
but is there any good working maxscript, tool, for painting hundreds of trees on a ground (mean also vray proxys if possible ? )
i also knew of a script, that positioned random scalled and rotated trees along a path.. nice also for example for streets…
any idea ?
should also work on win 64bit with max9 32 and 64 if available…
greetings,
Tom
You can use the crowd helper with proxies.
It’s close to a scatter with simple object.
Best regards.
Well,
thanks. One more possibillity.
but anything like the advanced painter tool, would be better and easier i think..
Tom
Hey Tom.
http://66.240.211.158/3ds-max/advanced-painter
Also, i do have a toolset, partially developed with joconnell, that does a similar thing: allows planting of trees on an arbitrary “terrain” within a boundary spline. Of course it’s at home with proxies.
It need authorisation, but being still in beta it’ll cost you nothing :slight_smile:
Message me on msn if you want it.
Lele
an other member on this forum cubiclgangster? pointed to this thing here:
http://www.max3dstuff.com/max4/scatter/help.html
and it does a good job, also with proxies, scale, rotate you name it, very powerfull!
Does it work with Max 9 ???
Best regards.
no idea, use it with max8 without any problems. i think you should just try it.
hi guy´s, thank you all.
lele: i already have seen the advanced painter thing. i allready did use it some time ago, but that was with max7 i think.
a friend of mine tried to use it on max 9 sp1 with windows 64bit, which didnt seem to work.
so ill send you a pivat message for your nice script. if thats allright (dont have msn here at the moment :wink: )
Tom
I tried to install it with VIZ 2008, because I used it quite a bit with 2007, but it no longer works.
Advanced Painter does though.
hi beestee,
did you also try it with max9 and 64 bit ?
Tom
