Any strings are added to a folder name by the Sparate folders feature of RenderElements?
Like:
\<Layername>_rawGI\…
\<Charactername>_rawGI\…
Thanx.
Like:
Thanx.
With ChaosGroup to no comment?
There are many requests from our customer.
It is very important at studio pipeline work.
Is there any other solution?
Can you clarify the question, because I’m not sure I understand it?
It would be best if you give an example for the final output filenames that you expect? Is it one of the following:
Case 1 (a common folder where all folders of render elements are nested) like this:
/commonFolderName/rgba/outFile_rgba.png
/commonFolderName/diffuse/outFile_diffuse.png
Case 2 (a common prefix for the folder of each render element) like this:
/folderPrefix_rgba/outFile_rgba.png
/folderPrefix_diffuse/outFile_diffuse.png
Case 3: Something else?
Case2 is the best.
I hope that a tag like <Layer> or <Camera> can be used.
Example:
File Name Prefix : <Scene>\<Camera>\<Layer>
RenderLayer : charaA
images\<Scene>\<Camera>\<Layer>
+ charaA_zDepth
+ charaA_zDepth.####.exr
+ charaA_velocity
+ charaA_velocity.####.exr
I will add this feature request to our “to do” list but can’t give an ETA on when it will be done.
Thank you for the consideration.
