any tips for saving the max 8 file back to the max7?
greeting everyone,need some help on my new project..
recently I 've receive a job from my friend, & by the time I almost finish the job I found out that they did’t have max 8 on their end(& they need to get the files render on their render farm):frowning: ..so …I knotice you can save the file to 3ds but this will lost all those vray setting & light casting in the scene(& that has took me quite an amount of time):frowning: ..pls help. thanks in advance.
Regards
Adam
hi ad-max,
look at this
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=15026&highlight=max
best regards
jonas
They could install the Max 8 demo and farm for 30 days :smile:
Hi Guys ,thanks for the reply:smile: …had done reserch on web too..found most of the answer are “no”:frowning: they have around 20 machine on their end so they are trying to avoid install max8 in all of their machine.. anyway thanks guys .
Had same problem
I had the same problem a couple of weeks ago. There is no real solution. Even if you export the 3ds objects into 7 from 8 the controllers get all screwed up. My post sparked a whole host of replies, people pissed at discreet for things being so damn difficult.
Sorry for you trouble :frowning: I know your pain.
there are ways to export some information from max8 to max7:
vray settings:
vray preset manager (script by marc lorenz)
http://plugins.angstraum.at/vraypm/index.htm
save the settings as a preset, reload them in max7
last time i used it was on vray 1.09
don’t know if it still works but at least you get the most important things over
geometry:
bobo’s BFF script
worked for me on a fairly large scene (max6-->max5)
or
fbx (filmbox)
or obj (try a search for habware and obj2max / max2obj if max7 has no native obj im/exporter - the native max8 version is the same btw)
standard max lights can be transferred - at least when using BFF and fbx
if you use vray lights, remember (write down) their settings and put a helper/dummy object on their position to make recreating them easier
ahh ..thanks guy.. :smile: I’m really greatfull for you guys reply ..will try your suggestion mike.edel :slight_smile:
