Anyone know of a utility to do this? I’d rather have the control of importing on our side rather than have the client export to DWG etc.
One would think Autodesk implemented this standard in 3dsmax but didn’t find anything. http://ifcopenshell.org/ifcmax.html this should do the trick. If you have access to Revit, you could import it into Revit and then export it to FBX.
Thanks for that. Seems to work a treat!
