ANYDESK Stop rendering
I occurs an issue with Anydesk, when my sceen is shared IR or standard rendering stop randomly.
(3dsmax 2021 - corona 6 hotfix 1)
Regards
We are aware of this, and currently discussing the issue with Anydesk team. The only known workaround for now is uninstalling Anydesk and using a different remote desktop app.
Please note that we are not implying that Anydesk is a “bad” software. The issue may be as well on our side. It’s just that right now we don’t know what exactly is causing this, so we can’t suggest any other solution.
This has started to happen with me and my colleagues aswell. We are using 3ds Max 2020 with Corona 6 (hotfix 1). Please keep us updated on this :smiley:
Would it be possible for you to submit a ticket and share some further details? https://coronarenderer.freshdesk.com/support/tickets/new
We have already contacted Anydesk about this and wait for further feedback.
Regards,
Hi, any news on this one?
Same happens here, with Max 2018, Corona 6 (hotfix 1) and windows 7 on remote machine.
Thank you,
Man
Which version of Anydesk are you using? We were unable to reproduce this issue. I would suggest updating to the latest version.
Also Windows 7 is no longer supported by Microsoft so it may be worth updating your remote machine to the latest version of Windows.
Cheers,
Rowan
Anydesk version 6.0.7
Yeah, I know it’s time to upgrade from Seven, it’s in the infinite to-do list…
If it’s a Seven problem than there is no choice.
Thank you!
Man
I am afraid, In all of the reported cases (regarding rendering stopping before render limit is reached) Anydesk remote desktop app was being used, and the render process abruptly stops when the user connects to the workstation/node device remotely. It seems that both local and remote clients are having firewall issues.
If experiencing disconnection issues, please make sure that exceptions have been made for AnyDesk on the firewall or any other networking solutions on your end. For more information, please visit their Help Center at Configure firewalls for AnyDesk. Lastly, you’ll want to make sure that nothing is obstructing ports 80, 443, 6568, or 7070 on your workstation-nodes. In case the issue persists I would also suggest contacting Anydesk support (do note that you need to be a customer of theirs in order to get assistance).
If possible, send them the trace files from one of the affected local and remote device pairs. Further instructions on where to find them can be found in Anydesk Help Center at https://support.anydesk.com/Trace_Files. As always, feel free to write to us at support@corona-renderer.com or reply here in this thread.
(Report ID=CRMAX-79)
I’m going to upgrade to windows 10 hoping to solve.
If problem will persist I’ll write here and will try to look at firewall options.
Thank you GeorgeK
Man
I have had the same problemof aborted renderings and tried to avoid remoting (ok corona-homeoffice makes this easy) for now.
Now in 6.2.3. it seems to work. But both devices are in the same network, i have to test more…
Switch to Parsec. Vastly better.
Agree on the Parsec, its wayyy better with colors and lag, plus the dual screen support is great.
