Ive recently purchased 2 xeon 5355’s and the above motherboard. I dont seem to be getting good results when it comes to rendering compared to my single quad core qx6700 system.
Running winxp 64 on both systems. Service pack 2.
Am i missing something in bios or maybe a microsoft fix ?
to be honest it all should work fine… but perhaps the Bios needs an update to make full use of the cpus? i would check the supermicro site for some updates
Well you have 2 quads there fore 8 cores.
Do you see all 8 cores showing up in the task manager.
At rendertime (not you Natty ) do you see 8 buckets rendering the image, and also are all cores hitting 100% during rendering?
Is it faster? or slower than your old quad.. post times of both is possible.
When its working properly, your new setup should be about twice as fast.
also you may want to download something like sandra lite from sisoftware and run a couple of test, just to check everything runs as it should.
and keep an eye on your system temperature during rendertime, if the cpus start running too hot that might result in a significant slowdown.
I can see all 8 cores being used when rendering using vray. They are all hitting 100%. The cpu temps are both showing about 48 degs. In fact, it feels like the heatsinks are hardly getting warm at all when i touch them.
Also, i rung supermicro and the tech guy said the bios doesnt address any performance issues…so he recommended not updating.
Everything looks fine (to me anyway): Does that core voltage look high to you ? It says on the cpu box 1.32v max Core voltage..althought when i check the voltage using superdoctor ( a supermicro daignostic tool) it tells me the cpu voltage is 1.31 which im more inclinded to believe.
What are your RAM and HDD(s) specs for each computer? 3GB switch for both?
Also, JIC, what video card and power supply?
We had some hard to crack issues that we eventually traced to our power supply in one of our comps a while back, we were underpowered because of our video card, and it made the system slow and unstable.
Dont need the 3gb switch…xp64 recognises max ram for both without that.
I have an nvidia 7800gt installed. I was thinking of taking this out to see if that made a difference.
The power supply is a hyper type R Mk II Series 680w.
I have three power cables going to the board…one large main power link, 1 4 pin 12v lead and an 8 pin 12v lead. I also have space on the board for a standard power cable insert, but i think you only attach that if you dont have the 4 pin lead.
If anyone at least has a dual xeon 5355 system can I please post a test scene to see what times you are getting in comparison to me. I really need to know if my cpus/motherboard are slow…I need to get them rma’ed asap if they are.
It’s safe to say that something is wrong, there is no way it should be 4x slower that the single quad.
I can’t remember if it has been asked but what speed is your memory running at? Sometimes if set to auto it can get it wrong, you might try setting it manually.
My next guess is that they are getting hot and stepping down, maybe try reseating the fans? Did you apply thermal grease or is it using a pre applied pad? Not sure about your MB specifically but you might try turning off the speed step stuff.
Also try a plain bruteforce render DMC for both 1st and 2nd bounce. That rules out any funnyness with LC passes or IR map. Do it on a simple scene tho just to be sure.
I would also run a few benchmark programs outside of vray. So see if its the cpus in general or something specific to 3dsmax/vray
You could try 3dmark and just run the cpu tests.
Or some video encoding tests perhaps.
Just downloading now. Will try that test in a sec.
Just to answer the questions.
My memory speed is 667 mhz. I dont think I can set the speed for the memory in the bios on the supermicro board I have. I can only change the voltage.
Also, i have re-seated the cpus already. Thermal (silver) grease was applied. The heatsinks (even under full load) dont really get hot at all. I have passive heat sinks with fans strapped to them.
SuperPI only tests single cores at a time. The results are the same for both systems.
Dont think its possible to turn off stepping on this motherboard either.
The memory was getting hot, but I put a fan over them and now they are keeping pretty cool to touch.
Ok. Here are some benchmark results from siSoft sandra. Cpu tests.
AS you can see all tests show the xeons about 2x faster.
And here are the results from the benchmark for vray:
And this is a simple scene with just brute force. Rendered out at 1500x1000 on both systems. (quad a lot quicker)
By the way, all the time these tests were running (under full load), the heatsinks remained pretty cool and the temps on the superdoctor app (by supermicro) said the cpus were around 40 - 48C.
