Anyone have experience of interiors configurators ?
I have a requirement on a project to be able to switch in/out different door frame and skirtings for a room.
The visual is of a door around which is a door architrave, with skirting along the bottom of the walls either side.
My client wants to set up a way for his clients to be able to see what this room would look like and have the ability to swap over different skirtings/architraves or adding accessories to both etc.
I’m thinking ‘configurator’ but don’t know where to start.
Does anyone have any experience of doing this and can point me in the right direction ?
Many thanks.
Take a look at a pass manager called reindeer or vexus - both offer automation to run loops of different combinations and should make your life a bit easier after the initial learning. The caveat is I’ve only used the standard bits in reindeer and haven’t touched any loop stuff yet but it’s listed in the features.
Thank you so much joconnell - I really appreciate that.
Yes, it looks like Reindeer would do what I’m after (as far as the 3DS Max side is concerned).
For those (like me) who don’t/didn’t have an idea how the output files from Max could then be taken care of web side, I’ve found (can’t thank Morne enough for this piece of help :)) that plugins like this one here - by WooCommerce will do that for you;
https://codecanyon.net/item/woocommerce-visual-products-configurator/9058551
