I can’t say it is urgent but I would definitely use it if you made it. The script I made automatically creates thumbnails of the last rendered frame and then applies a few simple effects (grid overlay, mirroring in x, and posterization) to help judge the quality of the image. I’m giving the script away and I figured it might be useful for the people here but I hit a snag with the V-Ray frame buffer. If I could grab a frame from the V-Ray RT window after major updates that would be great as well. Anyway, I very much appreciate anything you can do and understand if this isn’t something that can be done right away. I don’t have any impending deadlines resting on this or anything; it’s just a side project.
There is already access to the V-Ray RT window, as well as a MaxScript callback that is called when the image is updated - take a look at the V-Ray RT preview script for an example (it’s called vrayrtutils.ms in the scripts/startup folder of 3ds Max).
Unfortunately, I wasn’t able to find the file vrayrtutils.ms anywhere on my machine so I am assuming this is exclusive to VRay 2. I’ll have to revisit this when I make the upgrade from 1.5.
It’s called Automat Image Tools. Just a simple little script but does a nice job of helping to evaluate renders. It works perfectly with max frame buffer and V-Ray RT. I’ll add support for the VFB if that every becomes accessible via maxscript.
