I started out with the blurry metal material, and changed the reflection and refraction colors, and added a bump map. But it still doesn’t look anything like CORTEN.
Re: Anyone know how to make a CORTEN type rusted metal material?
CorTen has so little reflection it’s not worth having any in Vray and why would you apply refraction to an opaque material? On top of that the bump map would be so fine it’s probably not worth applying. I’d just find/make a good texture map and maybe apply a bump map if absolutely necessary- the hardest part is getting a texture map which tiles, but which shows the gravitational effect of weathering on CorTen.
I agree, and if you make your texture bigger than the largest sheet of metal (given that the sheets have finite size) then it shouldn’t be too difficult to make a texture. If you know where there is some corten, then you can take your own photo, or you could adapt a texture from say http://www.cgtextures.com/ etc.
Loac - any chance of posting the material? If not no worries… have navigated to the site dcauldwell mentioned and am about to attempt a material over the next few days!
Seeing as this thread is a year old and “loac” only ever posted twice, I think it’s unlikely that he’ll respond now.
As Danger Oux explained, you don’t even need a vismat for corten steel as it doesn’t require reflection, refraction or bump, just a decent rust image which can found easily with Google, Flickr or a camera.
