Special Thanks to Micha for his starter kit. The image based lighting bit really makes a difference. I’m still trying to figure out what the rest of the settings in his setup do.
Anyone want some tea?
Hello:
Very nice image. I am very new to VRay. I hope I can learn from the group, and one day be able to produce some decent presentations with it.
This render is absolutely WICKED
Andyboy, I will have to have a look at Micha?s starter kit
Regards
MarkO
Nice image!
Can you tell us more about how you textured it?
thanks
wow, terrific image indeed, very nice.
Yes, please provide some info on how you textured it.
So, where is Micha’s starter kit? Is it available to anyone?
starter kit → Chaos: Industry-leading design and visualization software
Thanks Micha.
Hoop
Thank guys
I textured it using spherical mapping for most of the elements. I generated the textures in Photoshop. I don’t remember exactly what I did in Photoshop. I think I started with a gradient, then added a noise filter then used a wind filter to get the streaky look. The spout was painted on a separate layer and then I did a series of test renders, moving the layer each time until it was in the right place. It worked fine because the teapot is so simple. It would be great if future versions of Vray would allow you to export uv maps as image files.
I’m having a bit of trouble with another project. A laptop with metallic paint. Anyone have any good examples?
Thankgs again ![]()
Andy
… and here an aniso test with different parameters from some weeks befor:
MISHA the topic about starter kit does not exist.
I see that there is some non public forum.
I have only demo, but my job is interior design, and becose i have problems with gi and lightning i bumped on other topic where you said that there is tutorial and settings obout that in non public forum.
I realy need that so i could evaluate this product.
So far i see that it is very good.
You can access that and other tutorials at our Wiki page.
The direct link to Micha’s starter kit can be found at
You can also get to our Wiki page from the Rhino Help Menu->Plug-ins->V-Ray for Rhino
