Anyway to save render as PNG 16bits
Hi, is that possible to change PNG to 16bits instead of 8bits when saving render? thx
When you change image output file path to .png you’ll see “Image Format” parameter group at the bottom, expand it and you’ll see “PNG” group. You could set bits there.
Ok I found it. Thx. What about if I don’t have output file path and I want to save from the VFB?
Those settings should be inherited by VFB, if not pls let me know.
