does anybody now how to get rid off those artifacts?
And include/exclude lists seem to be reversed.
Cheers …
Cheers …
A bit hard to see.
My first impulse would be to crank up the samples.
I pushed up the samples to over 100 and the effect didn’t change.
Could you tell/show us what exactly it is, maybe show the geometry and material settings? There must be a way to fix it.
Phong tag?
Phong tag has no limitation, this effect happens with low or high poly count and seems „show“ every single polygon.
I wanna achieve a smooth transition in the shown area for heated metal reflection.
Thx for that hint, I know different ways to achieve it, but I am curious how to avoid those artifacts.
That is why the topic is AO and not temperate metal on weldings.
Maybe someone from the developement team can lift the curtain.
Cheers…
I was able to replicate the effect. I tried the object with the basic UVs and cleaned up UVs. It’s pretty much the same.
My conclusion is that it’s highly scale dependent and sampling doesn’t do much, even at max values.
The sampling areas are not properly “connected”/smoothed into each other. I, as a non-programmer, see this as an interpolation problem.
Color spreading can make it a lot better but it can go off rails into unwanted areas and at some more distant AO’d areas, the artifacts still appear.
Spreading is not the same as smoothing, so there might be an option that is missing. Sampling is afaik just affecting the accuracy.
There sure are a lot of workarounds for that, though baking AO gave me the best results, even with the standard c4d baker.(btw you can convert the AO bake into a vertex map and it might be more flexible than a bitmap.)
A curvature shader should be best for that task.(hope we get one)
Hey guys! Just wanted to chime in before we find some time for this report!
It seems to me that this problem might be connected to geometry, so anything from incorrect normals and badly created geometry to Corona not interpreting valid geometry in a correct way. If I were you, I’d try to play with the phong tag settings or remove it altogether.
I tried different settings in phong tag, but that doesn’t have any effect.
Furhter more I checked vertex normals and everything looked fine. Every other render effect (fresnel, mapping, bump) looks alright, so I don’t think it is because of bad geometry.
It looks like every poly is handled seperately.
But thx for your reply anyway!
Cheers
I had the same effect with clean subD modeled geometry. Phong tag didn’t change anything.
Here’s my replication.
low vs high sub-division.
phong(pretty much any angle) vs none.
native c4d ao shader
edit: saved out the wrong file for opensubdiv. just lower the subdivision and change it and it becomes visible.
also happens with boole’d geometry.
I don’t know, man. I looked at your scene and it looks weird indeed, but I could not get C4D AO to look good either… Let’s ask Tom Grimes, what he thinks…
The C4D shader isn’t the best option either but it was the quickest example.
But hey, at least it’s not SSAO.
I also noticed a difference between IR(left) and Final.(right)
Terrifying but which is da wei?
Sorry, didn’t have time to look into this yesterday. That turned out to be potentially useful, as I did notice a difference with an SDS object in IR and offline rendering while working on other stuff, and it may be related.
I was using the free scene from Yarko Kushta / Studio Heisenberg at https://www.patreon.com/posts/free-scene-for-8459185 and with an offline render, I get artifacts on the curtain, but not in IR (image of the artifacts attached). No AO used here, but definitely something different with SDS in IR vs offline.
As well as similar results from native AO in C4D, the same thing also happens in Max.
Solutions that I can see for now are - the object is very small in scale, larger scales seem to work better; and of course raise the number of Subdivisions ![]()
