Apartment MZ
Hi everyone!
I’d like to share this interior restyling project for an existing apartment overlooking Lake Maggiore.
I created the renders on behalf of the interior designer, to present the proposal for updated furniture and selected finishes to the final client.
A light intervention, yet one that completely transforms the atmosphere of the spaces.
I’ve added a few short AI-generated clips from the renders, for social media and for the client presentation.
Oh these chips are amazing! Well done.
Do you mind sharing a bit about your workflow? Thanks.
Thank you so much!
The workflow I use is to render at twice the final desired resolution, using the Intel denoiser instead of Corona’s High Quality one, but setting the Image Filter to Tent instead of High Quality. I let the render run for about 30 minutes and stop it even if the noise is around 13–15%. Then I downscale the image in Photoshop to 50%, using “Bicubic Sharper” as the resampling method. I correct saturation and contrast in Camera Raw, and then I add people using Nano Banana AI instead of Firefly 3.
The image with the inserted person is upscaled in Magnific AI in two versions: one with all standard values using the Illusio engine, and another with creativity set to -4. I bring all three versions (the original and the two Magnific ones) into Photoshop and use masks to pick the best parts from each.
Once the image is finished, I animate it with Kling (version 2.1 or 2.5), setting the one with the person as the first or last frame (depending on the direction of the action) and the one without the person as the second frame. Then I write a short, straightforward description of what happens in the scene, as if it were a film script. The resulting video is usually at 1080p, so I upscale it 2x in Topaz Video using the Theia engine, and if needed, I slow it down by half. Finally, I use Filmora to edit the video, add music, and apply transition effects.
