Not really a showcase yet. Just finished a videorender and I want to know why it took me 20 hours to render.
Guess I did something wrong with my settings. I don’t know if the following settings ar also used for the video :
general tab > rendering quality : ultra
capture tab > resolution : 4K
video compression quality : email
The .skp filesize is 100MB, but the scene is FULL of proxys (approx. 1,2GB!)
Video compression has nothing to do with the render duration, it just makes the filesize smaller but at a worse quality. Ultra means that it’s higher than you would usually need and has no visual impact. High is enough for most usage and is much faster. Which version did you use? Also: Did you tune down the sun light intensity? Then, the scene becomes dominated by skylight which makes everything blue-ish.
Which hardware are you running this on? 4k rendering resolution is quite demanding for videos and might not always make sense, since most people still have only 1080p monitors.
Vendel3D, congrats for that panos tour, cna you tell us how do you make it? i mean, making that online pano tour after enscape, i think is a brilliant way to show clients
