Hi. I must launch manually cbservice.bin to make it work. Otherwise ChaosCosmos does’nt launch. Any idea ? Have already uninstall / install 2 times // Same pb. Config : MB Pro M1 Max / OSX Ventura 13.1 / Sketchup 21
Do you have this file: ~/Library/LaunchAgents/CCBService.plist
If yes, can you please execute the following:
launchctl bootstrap ~/Library/LaunchAgents/CCBService.plist
If none of the above works, can you please create an issue in our tickets system and attach your installer log (located in /Applications/ChaosGroup/ChaosCosmos/uninstall/install.log)?
