Apply video as a texture on the surface.
Hello everyone, using Vray for Rhino Is Possible to apply the video on the surface, to make an animation video That would move like a TV screen.
Is it possible?
Do not know if I was clear!
Thanks. ;D
Re: Apply video as a texture on the surface.
cad, i think you should look for a video editor, such as after effects, you could easily make that with that software.
YEP VFR does not support Video as texture, besides, Rhino Either.
Ok, thanks everyone for the help. ;D
I don’t know of any render program that lets you use video for a texture. After Effects if what I use, I render all of my objects in Vray, Set my HDRI, and drop the ground plane and environment to be a green screen color, and then add whatever video footage or backgrounds I need, all done in After Effects. The nice thing i am learning is that using Matrix/Rhino together with this Object Animation Builder, I have been able to create everything I need and want for my movie. It is far more simple, yet it is also advanced and has an easier curve then 3DS’ method. So, Create 3D Model in Rhino > Add material & HDRI > Drop Green Screen surroundings > Open Object Animation Builder > Set my camera paths > Render > Drop Footage into After Effects.
here is a low quality of one of my renders --> http://www.gemvisionforum.com/darrin\_smith/flight.mp4
3dsmax Scanline lets put a video as a texture.
