AQUA & OG (updated 2)
Simple studio setup with the classic glass test. C & C
click = HIGH-Rez
nikki Candelero
beautiful light and glass.
fabrizio
10
Well done!
Maybe too perfect to be a photo! :smile:
beautiful! the colors are gorgeous!
nice one!
May i ask what’s the ray depth?
They look so intricate in the refraction/internal reflection…
Lele
Thanks to all!
Both depths set to 15.
nikki Candelero
sweet / warm render and comp!! 8)
Aaaah. i knew early termination worked well, i just didn’t think it worked THIS well :smile:
Nice nice pics.
Lele
Splendid!
As all your works btw.
wow, very nice
classy and elegant looking,
great work
Impessive ! :shock:
Do you mind sharing your setup ? Is there a lot of post-prod ?
:smile:
Post - actually no, there is something like 1% PS and 99% pure V-Ray.
The setup uses 4 lights, 2 VRay planes and 2 VRay Spheres (color) lights.
An extruded curve spline is used for the environment.
nikki Candelero
Very nice… :slight_smile:
Do you have fog on in the glass material?
Thanks for the quick reply, Vray lights rulez !
I hope I can match this quality one day :stuck_out_tongue:
I found that using LAAAARGE vray plane lights with small multipler is much better than using a smaller one with an higher value… do you agree with that :?:
I often make my studio setup with 3 Vray planes, but i’ll try with some spherical vray light too !
Well, that depends a lot on the vision you are after. Larger lights produce softer shadows, and reverse. The light ratios, color gammas, location of the lights, composition, etc, they all need to be considered and how they affect the final rendering. :wink: :wink:
nikki Candelero
the softbox’s i used for product shots were no bigger than 3 feet x 3 feet. i know when doing something larger like a car the diffuser is usually alot larger
Yep, right!
Nice avatar, btw !
nikki Candelero
New images added !
nikki Candelero
hi candelero,
really nice! beautiful ambience.
but i think the orange needs a bit attention.
best regards
jonas
