Arcade Building...pahse one
Any comments welcom.
Regards,
Mike
Very, very nice. I like the exposure on the background photo too. Too many times we see darker outside environments, which is seldom the case in photography right?
The only two crits I have are:
At first i had a hard time seeing the dropped soffit. It looked like the chandelier was huge and over close to the wall.
The floor should be super smooth if it is hardwood. Unless it’s linoleum!
Thanks for the comments. The sofit is hard to see, but the clients picked the views themselves. Of course we tried to coax them into a more friendly angle, but…
The flooring is a fake bamboo, and it is a little to bumpy. I will fix that for the animations. The interior space and most of the models were built in
a day, and the total time for this was 2 days. There is very little post work done to these. I will post the view from the kitchen shortly. There is still a little Lighting work that need to be done, as far as the bleed/artifacts. Just
no time this round.
Regards,
Mike
Here is the kitchen view.
Regards,
Mike
AO used ?
verry nice bro… i like it very much! do you have vray dust on your ceiling and mocha walls?
Nice ones!
But I have this feeling no one is gonna be able to sit at that kitchen block where the newspaper lays :lol:
Funny that you mention that, because the client came up with that at the very last second. It wasnt even in the cad files. :smile:
Seriously, this is something that has to be fixed. There should be lower chairs or a higher kitchen plate (don’t really know how to explain this in english)
If I see this correct, it’s not possible to get your knees under it. There’s like only 5 cm between them..
Some references from Neufert to explain what I mean.
