1) New scene, add a teapot
2) Create a new material, use Arch & Design
3) Apply to teapot, render - looks fine
4) Create a new material, use Shell
5) Instance the previously created A&D material to both shell slots
6) Apply Shell mtl to teapot - renders black!
It’s been like that for a while; but we can only do the auto-conversion if the Arch&Design material is either directly applied on an object or inside a Multi/Sub-object material right now. I will make a note to add support for the Shell material too.
