Arch Interiors
Re: Arch Interiors
Thanks for the comments!
I think it’s getting better, but still I get some splotches on the two walls, maybe I don’t have enough light? The ceiling lights are linear, would lowering the shadow intensity help?
Somehow the image looks too neutral, I will try making darker blues and yellows for the lights as per Micha’s suggestion.
Rec Lights
Subdivs 16
QMC
Noise Threshhold 0.01
Min Samples at 8
IR Subdivs 99
LC Subdivs 1500, Samplesize .005
Re: Arch Interiors
The ability to globally change the gamma for textures would be excellent. I see one problem, or perhaps I don’t understand. For materials used for exteriors you don’t want to do this, correct? Perhaps there is a way to be selective about changing the materials. For instance we could keep groups of ‘interior’ and ‘exterior’ materials and only modify the one?
Re: Arch Interiors
Your lights (except direct light) should have the decay set to inverse squared, or just uncheck No Decay for rec lights. This is how lights react in the real world but remember that you will have to increase the intensity in order for the lights to have the same effect. Try adding more interpolation samples to LC, maybe from 5 to 10 or 15. Also adding more samples for IR might help too (not subdiv).
As far as gamma correction for textures, they should be corrected for interiors and exteriors. Most of the time exteriors can usually do without it, but it should still be there. With the new v4 beta the gamma correction is done globally, allowing you to change all the textures and colors with two clicks. Now that gamma correction is much easier, it would be good to have it checked, save it to a template, and you don’t have to worry about it again. Who knew LWF could be so easy :slight_smile:
Re: Arch Interiors
Has anyone tried using new physical sun a sky options for rendering interiors?
Re: Arch Interiors
I don’t believe that the vray sun/sky are in the beta yet. I’ve used it with Max on my last personal project, and it came out great. The only source of light was the sun (with the exception of one room)and it worked well, as there was a lot of windows and skylights and things. It really is a must to use the physical camera when using the vray sun. Its about the only way to counter act the sun’s intense brightness. I’m not really sure what your really asking about, especially since its not in rhino yet. Once it does get in there we’ll probably have a tutorial posted for it.
EDIT:
Sun/Sky aren’t in the current version, but will be in the next beta. It will also be possible to control the sun direction with the Sunlight command. The next beta version will also install McNeel’s RDK feature which adds the sunlight feature and safeframes as well…no more downloading Brazil.
Re: Arch Interiors
The Sun/Sky will make their official appearance by Friday of this week (16 March) - along with DR and a few other things here and there.
Re: Arch Interiors
Thats what Im talking abouth! ;D
