Archicad 29 teamwork file + Enscape extremely slow
>> Opening a Teamwork project with the Enscape plugin activated in Archicad takes me 7 minutes – Enscape plugin deactivated: 1.5 mn;
>> Enscape works in combination with a Teamwork project, but extremely slow. I tried to save my Archicad teamwork file locally as a .pla file, but that works still extremely slow
>> If I save a teamwork file locally as an Archicad archive file, it works more ore less like a standalone file. Enscape works fine. This is for rendering or visualisation purposes OK, but bad for the workflow because it’s undoable to incorporate all my changes back into the teamwork file.
Maybe a good suggestion to fix this?
Hi @Alex_Jager , welcome to the community!
Unfortunately, Enscape currently isn’t extensively tested with Archicad Teamwork. You may be able to recoup some lagging by reserving the appropriate libraries in AC for Enscape, but we cannot guarantee this will fix all cases.
Thank you in advance!
