I would say VW has the most superior 2D Features and usability.
But VW is a true 3D App since decades.
Of course it is oriented to a kind of 2.5D approach, which is very handy
for typical architectural work and thinking, but this is which is even more
true or restrictive in Archicad.
Beside that VW offers sufficient and comfortable free form modeling,
like SubDs, NURBS, NURBS Surfaces, non destructive Boolean Operations,
true Parasolid Modelling Core Solids Modelling, Surface Arrays and what not.
And all that geometry can be easily bimified by adding IFC Tags and/or put
into a Hybrid object for proper plan generation.
It is just that the VW Architectural Object Tools are not as detailed and sophisticated
as in Archicad. On the other side you are far more less restricted in design freedom
in VW, when it exceeds the limitation of the given parametric Tools.
But yes, in VW you can create absolutely beautiful 2D Drawings, Layouts and Plans
very easy and comfortable.
As I like parametric modeling with components very much for architectural projects,
I am a big fan of Archicad and had much fun with it.
I own VW and have fun with it too.
I think on the App graph from Design down to Bureaucracy looks like this :
Vectorworks → Archicad → Revit
(where each has its pros and cons)
