Rhino doesn’t close normally. It takes about 5 minutes before it is gone from the task manager. If you open a new rhino instance in that time, it opens very slowly. If you close the remaining rhino.exe with task manager, and then open a new instance, it also opens slowly.
The global setting: glossy effects, only affects highlight glossiness, not the reflection glossiness. It also doesn’t affect refraction glossiness.
GI color changes don’t come trough in the render, even after reopening the file. Putting in a hdri instead works.[/u]
- the cylindric point camera can not be controled
- light material: color multiplier dosn’t work (only the texture multiplier work)
- light material: light options are minimized after reopen allways
- gloabl disable maps dosn’t work for bump maps
If you all could keep posting found issues in this thread for beta 10 this would be helpful for us. We will add known issues to the beta 10 announcement post as they arise. Mostly because some of these issues are known but didn’t make it to that list. This will help people who are downloading beta 10 for the first time.
This is probably because the bump map will automatically displace shadows on the object to simulate the surface detail; negative bump values move the shadow points inside the surface causing it to self-shadow; I suppose this shadow correction should be disabled for negative bumps.
what controls are you expecting for it? None of those things apply to it. Height only applys to the Cylinder(Ortho). Override FOV isn’t hooked up yet, and the other values apply only to Fish Eye and Warped Spherical
Ahh, I see the problem. The interface is confusing. The color multiplier only works, if not a texture is assign. If a texture is assigned, than the texture multiplier works.
It is the old confusing game of the blend function. I would wish to get a single multiplier only. I have asked befor but get no answer: what is the advantage of the blend function? Why not a simple multiply function like in the renderman code language? surface color = intensity * color * texture :?
… if I enable “phong” than the objects is invisible. This option is sticky only if I render a material preview. But one time the material editor freeze and as I have try to close it → rhino crashes.
The BRDFLight is actual customized by me, it isn’t the stock VRay implementation so I suppose I could be doing it wrong, but let me show you how I do the BRDFLight.
// color = light_color * light_color_mult...
// so the light color mult is affecting even the texture...
VR::AColor final_color = combineTex(context ,color_tex, color) * color_tex_mult;
// so this grabs the color from the texture at the given context
// and combines it with the color...
Now this is the way most of the other maps work, am unsure which is better
// now here the color_tex_mult is used as a blend factor as opposed
// to an outright multiplier
VR::AColor final_color = combineTex(context, color_tex, color, color_tex_mult)
So the way I do the light map is just the straight up multiplier, whereas for most other maps the blend function is used. So what part is it that bothers you most? Do you not like blend functions outright, or is it my UI throws you off because I call it a texture multiplier but it gets used as a blend? Sorry if you feel we’ve ignored your concerns, there is a great deal of things that need attention.
Ok..well it looks like the new SDK doesn’t support anisotropy on phong brdfs. I’m not sure if this is intended or an accident, but that could explain the crash your having. I haven’t fully tested the phong stuff, so there may be other issues, but this was the first thing that I noticed.
actually it seems the phong never had anisotropy in it. I’m messing around with it now, and I’ll be speaking with Vlado about it next time I see him.
My english is not so good and so I will try to say it with easy words.
What do I want? I need a easy interface without double controls. I would like if I can adjust the brightness of a texture and correct the color. For example if I use a HDRI and I have the feeling it is to blueish for my scene, than I would like to multiply a yellowish color.
I have writen here Chaos: Industry-leading design and visualization software more details about the usage. Please tell me your thoughts about it. The biggest problem of the “blend” is, that the user can get strange results like inverted colors.
Bad news: all plugin materials from yesterday are lost and I can not reassign my exported materials, because the plugin material buttons are inactiv.
Good news: if I select an other Rhino renderer like Rhinoman and assign a material, than the buttons are enabled again. Now, in Vray mode, I can import my materials again.
… interesting. I have closed my Rhino and restart it again and open my critical scene file with the lost materials and … all materials are working now. Seems to be a temporal effect. Could be difficult to catch the bug. :?
Are you saying that both the “Create” and “Edit” buttons were greyed out? This generally only happens when a person switches between renderers and doesn’t refresh the object properties page. VRay for Rhino by itself should never have the “Create” button greyed out.
So you just want a simple generic multiplier without blend. I would really like to get more people’s opinion on this before I go and modify how each map in all of the brdfs work. So I will post a poll about it in the general forum.
One thing I definately need to do is change the wording from multiplier to blend and limit the range from 0 to 1. I apologize for not acting on this sooner.
