Archvision RPC Content Not Displaying in Enscape
I am currently working off of a trial version of Enscape and Archvision while I put together a sample project to sell my new firm on subscribing to both. The problem I’m running into is that the downloaded Archvision RPCs wont display in Enscape. They display fine in the Revit model, they have the water mark of course, but the family doesn’t display at all in Enscape, only the rpcs that came with revit will work. I’ve tried uninstalling and reinstalling both. I’ve tried unchecking replace RPC Content. Has anyone else had this problem and found a solution?
What do you mean exactly? Is there an empty space where they should be? Are they replaced with other content? If you want to use 2D RPC content from the RPC Dashboard, you have to toggle the “Replace RPC content” checkbox in the settings.
There is an empty space where they should be, I have toggled the “replace RPC content” Then relaunched enscape, the “out of the box” revit RPC files show fine but the downloaded content from Archvision wont display
Reboot your machine
Is the RPC content downloaded to your workstation and is the folder connected properly in the Archvision Dashboard?
Have you changed anything on the RPCs after you’ve inserted them into your model?
