I’m working on a medical animation and some of my materials were Autodesk Physical Material. We’ve had a weeks break in the project so I decided to upgrade all PC’s in the office to hotfix 1.
After a week, I have opened the latest files of the project and to my surprise, my reddish transparent material was simply frost white glass. Actually all my Physical materials have become somewhat different. Skimming through dozens of copies and backup files, I couldn’t find a single max file with my original reddish glass material. I decided to look at the files on the only PC that doesn’t have the upgrade just in case there might be some backups and the only scene file on the computer opened just fine.
I took the files to the other desktops and that is when I realized its about the upgrade.
You can see in the attachment both versions of the same material.
Luckily I 've had a PC that I haven’t yet updated. Is there a simple workaround option button to revert the Physical Material effect to the previous version.
I needed the physical material for seamless fades between different material effects and the material properties are already animated.That’s why switching to some other material is risky.
Edit: The Scale parameter under the Scatter Color seems inoperational in hotfix 1. It renders as if Scale value is set to 0.
