I have made a script that renders out each layer that is defined in Max (Hides all layers, turns one on, render. Turns one off, turns two on, render etc.)
Made this because i got a lot of products from a client and i have imported them all in the same scene, but in different layers. And they wanted still images of each product.
The problem i have is that i need to use Max feature of Blowup region render, and specifically “Auto Region Selected”.
This would allow me to select all objects in a layer and fill my rendering screen output window.
The problem is that Vray is distorting the aspect ratio (or something?).
See the attached images for comparison between Vray and Scanline.
Is there anyway i can use this function with Vray?
