Array and Live Link don't always work
So, when I’m using Live Link with Max, and then array an object, Vantage won’t render every object (see attachments).
Hi Dean,
Does it happen in V-Ray IPR? Do you mind sharing this scene as I cannot reproduce it on my end.
Alexander
Sending a file wouldn’t work, as as soon as you re-open the file, the objects are visible.
To replicate, it’s not always the same. When using the array (Tools - Array) you might need to set the array to a lot of copies / instances, and add rotation as well as position.
I will try IPR.
Thanks,
Dean
