Art gallery and Museum Entrance!
:slight_smile:
http://img229.imageshack.us/img229/5475/entrance.jpg
Re: Art gallery and Museum Entrance!
wow… man, i like the way you design…
great water, and great plants… specially the one in the front… looks soo realistic.
where did you get your floor from?.. i like it
jejejee, Thanks for you comment Omar Im So glad you like it, the floor textures its from cgtextures.com. : :smile:
really nice render…
only suggestions id say, theres a tiling error on the stone wall, when the wall turns 90degrees you can see the texture repeating to the left of the turn.
the soffit (timber ceiling)… for me looks tooo perfect, no joints in the panels etc. i think if you put these in then it would add to the realism.
great none the less,
kind regards
Thanks for the comments Deanfitton, and is true a had a mapping problem in stone texture I already fix that today, yes nice idea about the ceiling.
Very nice, Dave.
Where did you get the plants, especially the one in the foreground? Is that a Sketchup model? The texture mapping is great. :o
Have a nice day,
_KN
Thanks for the comment Ken, and the plant I get it from the google warehouse and I create the mapping, copy the plant 4 or 5 time and then rotate it. :slight_smile: and to add more realism I add a reflection layer. :slight_smile:
How do you make the wall brick or floor tile to not looking repeat like that?
I always have problems with repeating the mapping image and that make so not real…
Is there any tips??
Hello v_drift, it depends in the textures you use, are they high res ? what size they have? try to download in cgtextures.com but always download the biggest image for example 3200x1600, then edit the texture in sketchup, right click and select texture position. good luck :slight_smile:
oh…
so, its not just repeating small portion of image but its covering almost the whole wall using high res image?
wow…I didn’t know that… I only can find small ones like 4 tile/image…
so,with 3200x1600 image, how big can you cover with it? 20’x20’ ?
how do you scale it properly in sketchup?
Thank you!!
