When using Vray CPU mode ( in IPR and render ) - I’m still not certain if IPR is therefore gpu or cpu - There are artifacts when using SSS materials.
See the black areas that look clamped.
This does not happen in GPU mode ( when switching to GPU in the vray settings ) maya, and those areas look smooth and with the correct colors.
I’ve looked into color correction, unsupported nodes and color management and none of those seem to have any effect.
Following up on this - @vlado Do you have any idea if this is fixed or still a bug, or there is a workaround? The issue is made much worse on a new project, where black skin and the darker values are artifacting even more and are accutely visible.
Some extra information -
This seems to be related to SRGB color management. When set to Raw, and then gamma adjusted the artifacts / compression do not occur in the SSS ALSurface material.
