Hi, Strange problem here. ImageShack - Best place for all of your image hosting and image sharing needs
I’m getting some strange blotching through my glass material.
I’m using LC 1000 samples
IR map high setting.
1 vray dome light with store with irmap checked and set to invisible.
some vray ies lights elswhere
glass has affect shadows checked, fresnel reflections.
Vray environment has a HDRI in the refract/reflect overide.
The glass object is an AEC railing but i checked with a box and I get the same artifacts.
Any ideas or help on this one?
Cheers
Ok so I deleted the vray dome light and replaced with a white environment…Problem solved!
never had a problem with the dome light before though???
It might be because of the different reflect/refract override; it might also be because of low refraction depth. Does it go away if you do not store the dome light into the irradiance map?
Hi Vlado, Things I tried but did not work were:
Switching off the vray IES lights
Increasing the refraction depth of the glass
Not storing the IR map with the Dome light.
I also got rid of any overides in the Vray environment.
Merging the scene into a fresh one.
Ensuring there were no standard or other materials in the scene
Physical camera / max camera
The instant fix was getting rid of the dome light and using a white environment. But for some reason it was the last thing i tried! Oh well, back on track now!
