Please is there a proper tutorial on how to use each of the sphere, spot, line, rectangle and disk enscape light objects in sketchup? And also explaining how to control each at daytime and night time? Thanks
+1 for this.
I make the 3 or 4 clicks required to place a spot without really understanding what each one does, a simple set of tutorials would go a long way to me getting better lighting.
:thumbup: good suggestions from both of you - also for me all this is a randomly clicking so far and looking, what happens.
very interesting for me: how to adjust artificial interior light sources in combination with daylight …
Thanks for your tutorial inquiry. We’re working on a blog and video tutorial about lighting. It will be published by the end of month. :thumbup:
Is that also Revit?
One at a time ![]()
The new blog post that is in production right now is focussing on Lights in SketchUp.
However, there is a blogpost about Lighting and Exposure with Revit: https://enscape3d.com/best-practices-for-lighting-and-exposure/
Please have a look on our newest blog post: Best Practices: Lighting in SketchUp
:thumbup: thanks !!
Seeing this video above the screen is all black in Enscape. Which settings do you use to get the black night time scenes with stars and moon visible? I can only get dawn/dusk with sun lit up the sky
I use SketchUp 2018
If you use the SketchUp time setting then it’ll only fo up to 10/11ish pm but if you change the time in the Enscape window (shift+right mouse button) you can set it to anything.
You can manually type in a time that’s out-with the slider in SU - just type 23:00 in the box (in the sunlight/shadows docker)
Thank you Paul. I didn´t know that . just noticed it in the Enscape panel.
This is probably not the panel you are talking about since it is not possible to type in here
Great Thank you!. Allways something new to learn ; )
Wow… Really helpful
Thanks a lot Jörg
Amazing
Minh, always on point… :thumbup:
Interesting video. For example the light source size radius control is a nice feature. But how to get it controlled at Rhino? I’m not sure it is possible, but it could be useful, if the size could be set 0 and the specular effect is invisible. (I know this possibility from Vray and there it helps to fill spaces with light without specular effect everwhere.) Couldn’t the unused shadow slider not be used? Also it could be great if the size parameter could be used to adjust the softness of the shadow too, like in the real world - bigger light, softer shadow.
Also interesting to see - the linear light. I never used it. Looks like the light distribution at 5:06 needs some improvements. I tried to use it as a long wall washer but without success.
