Artificial Lighting trouble
Hi all-
I’m new to Corona, and am having trouble with artificial lighting. I’d like to produce a warm, diffuse lighting from a lamp and am attempting to use a CoronaLight to achieve it, with no luck.
I’m attaching an image of the desired effect vs my result. There is a Disk shaped CoronaLight in my scene emitting light, but no matter what the intensity setting is, the result is always very harsh and produces a hard-edge around the light. I’d like the result to be more diffuse. Tips? Tricks? Tutorials? Thank you so much in advance!!!
Best,
Mia.
Can you show your Corona light settings? It could be that you have set directionality way too high.
Hi, yes, sure.
I have the intensity set at 100 def, and I tried turning it down to 50 but the light never becomes diffuse. I’m attaching images.
Never use directionality above 0.5, otherwise switch to std 3dsmax lights :wink:
Yep this is Directionality, at 1 you are pretty much making a laser :smiley:
Yes that did it! Thanks so much!!!
