Artificial lightning problem
Hello!
I really need help with rendering in Enscape - artificial light, I'm a beginner and I don't know what to do - I didn't find anything on the internet.
I have modeled a house in a sketchup, its facade is made of polycarbonate. The idea is that the house will be visualizated in the morning to stand out its translucency. Everything looked fine all the time and suddenly something have happened - artificial lighting started to appear very strange after rendering (it seems to me inversely). Where could the mistake have happened? Did I accidentally click on something in the settings menu?
The first photo is what the draft preview looks like (seems ok to me). The second photo is what is actually rendered. The third photo is what it looked like before I somehow messed it up and I would like to get back to that. Thanks for any tip!
Hello @kaiape
Welcome to our forum.
Please make sure your graphics card is up to date, as this may also sometimes cause this kind of behavior.
If that doesn’t help, to see if this is a visual settings issue you can always try if resetting them to default as seen here resolves this.
Otherwise, are you able to share the model with me to test this locally?
You can simply send a WeTransfer link to me via a DM and I will check it out.
