ARUP HQ in Singapore
Completed last year. Headquarters for ARUP engineering and design firm. Fitout designed by HASSELL.
It was a fun tight project.
These are great! What material did you use for the spray insulation at the decking. Also what did you use to model the duct work. These are always a pain for me. I’m also glad you added all the supports. Nice detail.
@nac23
Spray insulation is Stucco07 from Poliigon - https://www.poliigon.com/texture/stucco-07
Duct work is from 3dsky - 3D models for design and architecture – download on 3dsky
Hope that helps.
I have a similar scene, open office like this one, but the light coming from outside is so bright, it is burning all the window area… I am using corona sun+sky.
How did you manage to find a right spot in the camera settings for the dark interior and bright exterior?
Thanks!
@Erald I gave up on photographic settings. I only use EV.
I set my HDRI/Sun to a normal value and build all other lighting up from there. And I use highlight compression.
I like these. I did some similar office interior views recently.
Though 2 notes which really bug me;
  • Those pots (and plants) are WAY overscaled. Something is very wrong here.
  • Your vertical alignment needs to be enabled in camera settings. Every view is slightly skewed in the Z direction and it kills your images.
Otherwise, nice work.
Thanks! I am using photographic settings instead. Will give it a try illuminating with a HDRI instead of a sun. Maybe it helps…
What maps did you use for the background? I like them, can you give the hdri name?
