As soon i use chaos scatter IR re parses all with every cam move
HI
for some reason here, when i use chaos scatter in my scene, in IR every camera move initiated a full scene parsing.
i guess/ hope this is a bug.
can you check that, as the scene and scatter not changes in relation to camera i think it should not need a new parsing of the scene, that makes IR not interactive any more. As soon i hide the scatter objects, IR is interactive gain without re- parsing the scene.
Or do i oversee something?
thanks for help!
Stefan
Sure, would be much better, if it got “frozen” like displacement.
Hi Stefan, are you able to share a video of this happening?
yes i can make a screencast tomorrow
here a screencast:
i tested with the chaos scatter items off and on,
  • having the scatter objects OFF, lets the IPR be used as usual
  • having the scatter items ON (using mostly cosmos items) lets the ipr re render form start with any change, even just moving the camera(basically not being an IPR anymore)
hope you can fix that, corona 8 and scatter and cosmos are great otherwise! :smiley:
Hi Stefan, thanks for adding the video. We will check it out. Were you able to test out the V9 daily as well to see if it happens there as well? If not, could you and let us know?
yes just tested in latest daily v9 build, it has the same issue still there.
(in scatter objects i have no camera clipping or the like enabled, so no reason that it full re exports all at a camera move)
any news on that?
p.s the same elements scattered via mograph work fine, so i feel it is some issue IPR connected to scatter with vrmeshes?
any news on that?
Hi Stefan, is this still happening for you? If so, can you share another video as the previous is no longer active? Thanks in advance.
Hi Stefan,
We are still having trouble trying to reproduce this. If you can share a test scene for us, that would be great!
