Ask for help, how to set corona in Paticle View
I am a newbie, ask for help, how to set corona in Paticle View
I am using Corona renderer, I am following the video, but when I go to 7:30 I don’t know how to set up my Corona, I have set Render Type to Geometry, but it has not changed when rendering.
How should I set it up, Thank you very much
Indeed, Corona does not respect pflow render type settings. Must be a bug. I will report it to the Team. Meanwhile, you can select pf source object, go to its object properties and uncheck renderable. That should work.
