Would be great to have Aspect Ratio and Resolution options in the Corona Camera as well as Presets similar to the free script CameraResolutionMod
+100 - this is something that we’re currently solving with scripts but if it was built in to coronacamera…
And I didn’t want to start a separate thread for this, because it is related, but another thing we would love to see in the coronacamera is a simple “portrait mode”, so that when you shoot a real photo in portrait on a 24mm lens, when you try to camera match this using coronacamera it’s currently a real pain as you need to do the maths to convert. If this was all built in to the coronacamera it would save a lot of time.
Cheers,
- 100
Really very practical. If we have this, we will not be able to go without.
+100 But—
may be many problems with DR, backburner ,deadline and etc.
@Alex, when you rotate the real camera to portrait the film size rotates from 36x24mm to 24x36mm. So when doing portrait mode in 3D the film size should be 24mm.
Br, August
yes finally! Autodesk are you listening?
Ah yes! Forgot this trick. Quite a nice workaround, although it would be nice not to have to rotate the camera, if we could have an override/checkbox in the camera itself it would still be my preference, personally.
Cheers,
The thing is - you don´t rotate the max cam. Just set the film width to 24mm and output size to portrait with image aspect=0,67777. Then the 24mm max cam performs the same as a real rotated 24mm cam in portrait mode without adjusting the focal length.
/august
up, any news?
(internal note: id=296115491)
+1
+1
