Aspect Ratio
Can we please fix the issue where if i change my rhino’s viewport aspect ratio, it changes the output image from Enscape as well, even though the resolutions are already set and camera never changes spot.
I do a lot of post processing after I get my exported view, it is critical for each export to match spot on, so if I were to change an element in the render, I won’t have to change everything in my post processing file to match it.
Also this hinders working in a group, where multiple designers are working on one image, all the exports from different computer should be identical regardless of the rhino view port ratio or monitor sizes.
+1!!!
(I know how frustrating it is if a new rendering doesn’t match to a series of images rendered a few days ago. I hope you get more attention for this very critical problem than I got in the past. :wink: )
was this ever resolved??
No, but I’m sure the request will get an upvote … only. ;(
I’m afraid not, it’s on our agenda though and I’ll make our developers aware of the further demand for a corresponding implementation to help with this.
It seems like it has the same glitch in Sketchup but not in Revit… Can you confirm?
I Think that technically speaking… its very easy to implement.
just add an option to open the enscape window in a fixed ratio (16:9 for example)
that way your final render will always be the same
